How to handle the connectivity issues for certain wireless clients with some APs?
Zyxel_Judy
Zyxel_Judy Posts: 2,739
image  Zyxel Employee
You can fine-tune the wireless environment to improve connection by implementing the below configuration.
Navigate to Access point > Configure > Radio settings
Deployment selection and Maximum output power
Select the Deployment selection according to your number of APs or adjust your 2.4GHz radio power to 5dBm lower than your 5GHz radio at least 5dBm. It helps the client is easy to connect to 5GHz that less interference, and up to 25 channels are available and non-overlapped.
Channel width
Narrow channel width to minimize co-channel interference on each radio.
DCS setting
Do DCS setting to ensure the AP can have the best channel.
  • Enable DCS schedule to let AP choose better channel for the day
  • Disable "DCS client aware" to let the AP jump to the better channel when the DCS work and there are still clients connect to AP.
  • Disable "Avoid 5G DFS channel" to let the AP have more options to prevent channel interference.
Zyxel_Judy
