How to enhance Wi-Fi Signal Strength when Deploying APs?
Zyxel_Bella
Zyxel_Bella Posts: 620
Zyxel Certified Network Engineer Level 2 - Switch Zyxel Certified Network Engineer Level 1 - Switch Zyxel Certified Network Administrator - Switch 50 Answers
image  Zyxel Employee
The placement and environment of your Zyxel device significantly affect the Wi-Fi signal strength.
1. Central Location: Place your Zyxel device in a central area of your space for uniform coverage. Avoid corners or distant rooms.
2. Avoid Obstructions: Keep the device away from physical obstructions like walls, large furniture, or metal objects that can weaken the signal.
3. Steer Clear of Electronics: Electronic appliances like microwaves or cordless phones can interfere with Wi-Fi signals. Keep your device away from these.
4. Elevate the Device: Positioning your Zyxel device at a higher point can help in better signal distribution.
5. Avoid Hidden Spots: Placing APs in cabinets, behind TVs, or in closets significantly reduces signal strength. Always opt for open, unobstructed locations.
