How to effective management of AP for Nighttime Deactivation with Nebula?
Zyxel_Bella
Zyxel_Bella Posts: 588 image  Zyxel Employee
Zyxel Certified Network Engineer Level 2 - Switch Zyxel Certified Network Engineer Level 1 - Switch Zyxel Certified Network Administrator - Switch 50 Answers
Efficient management of network resources is crucial, especially for wireless access. An important aspect of their management involves the ability to control their operational status, such as deactivating them during non-business hours for security and energy-saving purposes. This guide outlines the process of managing APs, focusing on nighttime deactivation.
Topology and Scenario
Gateway --- Switch --- APs ))) Clients
Configuration
1. Go to Access Point > Configure > SSID Schedule.
Set SSID off times to disable WiFi module during those periods.
Reference for SSID scheduling:
2. For physical AP shutdown, consider PoE switch scheduling or a smart timer plug.
Verification
Check SSID schedule activation, expected outcome is SSID turns off at set times.
Noted
SSID scheduling only disables WiFi, not the entire AP.
No physical button on AP for direct shutdown.
