How to troubleshoot when USG FLEX H is freezing and not responding?
Zyxel_Emily
Scenario:
This article describes troubleshooting steps to take when the USG FLEX H becomes unresponsive.
If the firewall is freezing and both GUI and SSH are inaccessible, connect console cable to the device and open TeraTerm. Serial Port > Baud rate: 115200.
- Check if console is still working when you enter any commands on console.
usgflex700h> show version
usgflex700h> show interface vrf main - Ping 8.8.8.8 from device on console and check the result.
usgflex700h> cmd ping 8.8.8.8 - Connect one laptop in LAN and ping the device LAN IP. Check if there is any ping loss.
- Collect diagnostic file.
- Collect diag-info BEFORE you restart the device manually.
Note: if diag-info cannot be collected before restarting, use "send break +x" BEFORE restarting the device manually.
For example, click "Send break" on TeraTerm and then enter "x"
- Restart the device manually.
- Collect diag-info AGAIN after the device boots up. You can collect the diagnostic file on GUI or CLI.
Collect diagnostic file on GUI
Collect diagnostic file using CLI
- 245 Nebula Ideas
- 6.9K Security
- 813 USG FLEX H Series
- 393 Security Ideas
- Threat Watch!
- 88 Switch Ideas
- 60 Wireless Ideas
- 7.3K Consumer Product
- 333 Service & License
- 543 News and Release
- 106 Security Advisories
- 5.5K FAQ
- 89 About Community
- 125 Security Highlight
