Is an SSID voucher code restricted to a specific SSID?
Zyxel_Judy
Zyxel_Judy Posts: 2,726 image  Zyxel Employee
edited February 2024 in SSID
No. It's important to clarify that the SSID name indicated on the voucher serves as a reference and does not restrict the voucher's use to that specific SSID.
For instance, if you print a voucher with "My 2nd SSID" as the reference name, this voucher remains valid for any SSID enabled with the voucher feature. Therefore, a voucher printed for "My 2nd SSID" could also authenticate access to "My 1st SSID" in the given environment.
In summary, any voucher generated in a site is applicable to all its voucher-enabled SSIDs, regardless of the SSID name printed on it.
To know how to configure captive portal with Voucher, please refer the FAQ.
Zyxel_Judy
