NWA50AX - wifi client looses connection
I have two NWA50AX at my site. One (living room) is hard wired to my modem the other (central hall) is wireless connected to the root AP. Smart mesh is on, as well as Smart steering and DCS scheduling. Also Assisted roaming and 802.11r are enabled.
All works okay, but there is one device/client (smart wifi speaker) which looses its wifi connection all the time. Sometimes after 1 day sometimes a little longer, but is does loose it. When lost, it does not reconnect automatically, only powering off and on the speaker/device works.
I believe it is definitely the second, wireless \connected AP (Hall) which causes this. This is the AP where the speaker is connected to (closest by). I tried putting the speaker close to the first (main/root) NWA50AX AP and it stayed connected for over a week or so. Also i tried a different (brand) AP (my old one) just for testing, and with this one connection stayed okay as well.
What can cause this lost connection and i can i fix it?
Hello @kaajee
⇒ Do you mean that the speaker lost the WiFi connection after being connected for about a day, and rebooting the speaker has been the only way to re-establish the connection?
Are any other devices experiencing similar connectivity issues? It would be helpful if you could provide the model name of the speaker and any other devices facing the same problem.
Additionally, to assist you more effectively, we recommend enabling Zyxel Support Access. Please also provide the name of the speaker (or its MAC address) if you have multiple speakers on your site. You can send this information via private message for privacy reasons.
Nami
- 241 Nebula Ideas
- 6.8K Security
- 755 USG FLEX H Series
- 380 Security Ideas
- 58 Wireless Ideas
- 7.2K Consumer Product
- 321 Service & License
- 518 News and Release
- 100 Security Advisories
- 5.3K FAQ
- 90 About Community
- 119 Security Highlight
