How to provide a custom name for a client in Nebula?
AnthonyZyzelUser
AnthonyZyzelUser Posts: 2
Third Anniversary
image  Freshman Member
I am going nuts because I did this once this morning and can't find it again in the Nebula interface. Where in the Site-Wide > Clients area can one enter a custom name to replace the MAC string. As you can see, half of mine have custom names already. The Doorbell Cam one I set a few hours ago, but I can't remember how. There doesn't appear to be any ability to edit the client record by clicking on the linked name, that's just status info and you can edit and add a note.
  • Zyxel_Melen
    Zyxel_Melen Posts: 5,207
    image  Zyxel Employee
    edited February 2024
    Hi @AnthonyZyzelUser,
    Thanks for your report. We are investigating this issue and will keep you posted.
    Zyxel Melen
  • Zyxel_Kay
    Zyxel_Kay Posts: 1,279
    We apologize for any inconvenience it may have caused. We've investigated the matter and have implemented a fix for the issue you encountered.
    You should now be able to easily configure the client name in the Site-Wide > Clients. Please give it a try and let us know if everything is working as expected on your end.
    If you have any further questions or concerns, feel free to reach out. We're here to help!
    Kay
Nebula Tips & Tricks
