USB Power
Gareth
Can you please go back to producing a mobile router that has a battery and usb power in like you had in the LTE3302 so that it can be used as a portable router rather than needing a mains socket all the time. The only options now are the little mobile broadband portable units you do but these switch off when not in use and only support a few devices and no rj45 connections etc. The LTE3302 was perfect for setting up a mobile network wherever you were and didnt rely on needing a dedicated mains charger. Just simple little change on the back of the router such as the NR5101 and this would be a perfect travel router
- 244 Nebula Ideas
- 6.9K Security
- 799 USG FLEX H Series
- 392 Security Ideas
- 88 Switch Ideas
- 59 Wireless Ideas
- 7.3K Consumer Product
- 328 Service & License
- 532 News and Release
- 104 Security Advisories
- 5.5K FAQ
- 91 About Community
- 124 Security Highlight
