It does not work!
Hi @KMarc
It appears that the LAN2 interface is currently in use (referenced) within the VPN settings, which is why it cannot be deleted from your firewall configuration. To resolve this issue, please navigate to "Site-wide > Configure > Firewall > Site-to-Site VPN" and disable the LAN2 interface from the local networks setting. Once this is done, you should be able to remove the interface settings without any problem.
Hi @KMarc
- 244 Nebula Ideas
- 6.9K Security
- 805 USG FLEX H Series
- 392 Security Ideas
- 88 Switch Ideas
- 60 Wireless Ideas
- 7.3K Consumer Product
- 333 Service & License
- 540 News and Release
- 106 Security Advisories
- 5.5K FAQ
- 89 About Community
- 124 Security Highlight
