[NR5101] Setting up an Ethernet connection
Zyxel_Kay
Background:
The NR5101 offers two options for WAN connection, which are through Cellular WAN and Ethernet WAN. If you connect to the internet through an Ethernet connection, you need to connect a broadband modem or router with internet access to the WAN Ethernet port on the Zyxel device. You need to configure the internet settings from the broadband modem or router on the Zyxel device. First, ensure you have internet access through the broadband modem or router by connecting directly to it.
Solution:
- Log in to the NR5101 local web GUI
- Navigate to Network Setting > Broadband.
- Switch to the Ethernet WAN interface, and enable the Ethernet port LAN1/WAN to WAN. By default, this state is disabled and the LAN1/WAN port is WAN.
- Once enabled, the device will reboot.
- After reboot, please navigate to Network Setting > Broadband > Broadband, and modify the ETHWAN.
- In the Edit WAN interface, you may configure the DHCP-Static IP or PPPoE. The default option is DHCP.
- If you choose PPPoE as your encapsulation, kindly insert your PPPoE account and password properly.
- If you choose IPoE as your encapsulation and are using a Static IP, you have to insert the IP subnet and gateway.
- Once the settings are done, click Apply to save all the settings.
- Then, you may verify your configuration on the Homepage Dashboard > System Info, the WAN Information Link Type will be Ethernet WAN.
Kay
- 244 Nebula Ideas
- 6.9K Security
- 805 USG FLEX H Series
- 392 Security Ideas
- 88 Switch Ideas
- 60 Wireless Ideas
- 7.3K Consumer Product
- 330 Service & License
- 540 News and Release
- 106 Security Advisories
- 5.5K FAQ
- 89 About Community
- 124 Security Highlight
