[Mobile router] How to fix the Cellular Signal LED showing Red of FWA510?
Zyxel_Bella
When the cellular signal LED on your FWA510 modem turns red, it's signaling an issue with signal reception. A constant red light indicates weak signal strength, while a flashing red light points to an absence of cellular signal or extremely poor signal strength.
Here's how you can address this signal issue effectively:
- Shift the Position of Your Modem: Experiment with placing your modem in various spots around your location to find a spot with stronger signal reception. Ideally, position it close to a window or at an elevated spot in your building for optimal signal reception.
- Attach an External Antenna: Boost your modem's signal reception by attaching an external antenna. This step is particularly beneficial for those situated in areas known for weak cellular signals. An external antenna can provide a significant improvement in signal strength, making it a worthwhile consideration for enhancing your connection quality.
- 242 Nebula Ideas
- 6.8K Security
- 779 USG FLEX H Series
- 387 Security Ideas
- 58 Wireless Ideas
- 7.2K Consumer Product
- 324 Service & License
- 527 News and Release
- 101 Security Advisories
- 5.3K FAQ
- 91 About Community
- 121 Security Highlight
