Firmware Update VMG3006-D70A Problem
2»
  • Peter2
    Peter2 Posts: 180
    image  Master Member
    edited April 2024
    I already gave you the links for a solution via ftp see above !?
    another hint to ssh :
    »»» May be you can try to disable the parameters "modelcheck" and "fwidcheck" via ssh to allow firmware upgrade when the cause is e.g. special ISP firmware version over web gui like below :
    … lesen musst Du schon selber ;)
  • Alex_DE74
    Hihi! ;-)
    zycli: not found
    What can i do?
  • Peter2
    Peter2 Posts: 180
    image  Master Member
    I really dont know, it is only a chance , and if its possible it is on your own risk ….
  • Alex_DE74
    Thanks/Danke @Peter2
    The attempt is failed.
  • leofrenchhere
    leofrenchhere Posts: 1
    image  Freshman Member
    If you're facing issues updating the firmware on your VMG3006-D70A, start by verifying your current firmware version through the device’s web interface (typically at 192.168.1.1) and ensure the new firmware matches your exact model and regional variant. Download the firmware from Zyxel’s official website, ensuring the file is in the correct format (e.g., .bin), and extract it if necessary.
