Same double SSID in Nebula Summary Report
Is it normal in Summary Report / Top SSIDs by usage
that I see two SSID networks with same name? One used at 100% and one at 18.2%, as if they two separate networks?
Could the security router's network be seen as "different"?
The network is the same, the broadcasting is configured on "all APs" (2 access points and 1 security router). There are no tags in the APs.
Thanks.
Regards
Hi @Sergi330
Thank you for bringing this to our attention.
This behavior is indeed a bug; the SSID should not separate into two entries. We are currently working on resolving this issue. Rest assured that as soon as there is any progress or update regarding this matter, we will make sure to inform you here.
Thank you for your patience and understanding.
Kay
- 244 Nebula Ideas
- 6.9K Security
- 805 USG FLEX H Series
- 392 Security Ideas
- 88 Switch Ideas
- 60 Wireless Ideas
- 7.3K Consumer Product
- 332 Service & License
- 540 News and Release
- 106 Security Advisories
- 5.5K FAQ
- 89 About Community
- 124 Security Highlight
