Overview and Installation Guide for SUPERGO-GE
The SUPERGO-GE Ethernet Surge Protector (SURGEPRO-GE) is designed to shield commercial networking equipment from power interference, ensuring data security and prolonging device lifespan. This guide provides easy-to-follow instructions for installing and maximizing the benefits of this essential device.
Disclaimer!
This article offers a general overview of the series and may not apply uniformly to every model, software/firmware version. Before purchasing or using the device, please consult the model/version-specific documentation or reach out to technical support for accurate information.
Benefits:
- Protects high-speed networks from surges and electrostatic discharges.
- Cost-effective solution for safeguarding Ethernet devices.
- Compatible with Power-over-Ethernet (PoE) and non-PoE devices.
- Supports connection speeds of up to 1 Gbps.
Specifications:
Important Notes:
- Ensure proper direction of installation with the ground cable connected to a grounding terminal to effectively protect against lightning and high-voltage surges.
- Do not connect Ethernet devices to power during installation.
- Avoid overlapping Ethernet cables connected to OUT (protected LAN) and IN (Surge) to prevent high-voltage surge transfer.
- Make sure the on-site grounding terminal has an earth resistance of less than 5 ohms or complies with electrical regulations. If unsure, consult an electrician or relevant authorities.
The following Table shows the Behavior of the SUPERGO-GE LED.
Ethernet Device | SUPERGO-GE State | LED |
With PoE Power | Functioning | OFF |
With PoE Power | Non- functioning, replace the SUPERPRO-GE | ON |
Installation Steps:
- Grounding Connection:
Secure the SUPERGO-GE's ground cable to an on-site grounding terminal using a grounding screw (not included). - Connecting Protected LAN:
Connect an Ethernet cable (less than 20 cm) from the OUT port of SUPERGO-GE to the Ethernet device to be protected. - Surge Connection:
Use an Ethernet cable to connect both IN ports of SUPERGO-GE.
By following these installation guidelines, you can effectively protect your network equipment and ensure uninterrupted business operations with the SUPERGO-GE Ethernet Surge Protector.
For additional resources and information, please visit the following links:
More information:
Kay
- 237 Nebula Ideas
- 6.8K Security
- 740 USG FLEX H Series
- 376 Security Ideas
- 58 Wireless Ideas
- 7.2K Consumer Product
- 319 Service & License
- 512 News and Release
- 99 Security Advisories
- 5.3K FAQ
- 91 About Community
- 119 Security Highlight
