How to improve Mobile Router connection by implementing daily reboot Maintenance?
If you're experiencing frequent interruptions in mobile router internet connectivity, your router may be encountering connection stability issues with base station. To address this, we recommend implementing a daily reboot maintenance schedule. This will enable the device to reconnect to the base station daily, improving signal connections and potentially resolving stability issues.
There are two ways based on different models or management mode to schedule daily reboot:
1. For the device managed and supported Maintenance function on Nebula:
Go to Site-wide > Devices > Mobile router > Maintenance > Edit > Enable the schedule > then select your preferred days and time to apply.
2. On the device local GUI > Maintenance > Reboot > Schedule Reboot > Set your preferred schedule to perform reboot.
- 244 Nebula Ideas
- 6.9K Security
- 799 USG FLEX H Series
- 392 Security Ideas
- 88 Switch Ideas
- 59 Wireless Ideas
- 7.3K Consumer Product
- 328 Service & License
- 532 News and Release
- 104 Security Advisories
- 5.5K FAQ
- 91 About Community
- 124 Security Highlight
