Is VMG4005-B50A easy to use in the UK on BT Openreach Fibre to the Cabinet VDSL?
tonygibbs16
in Home Router
I wonder if anyone can tell me how easy it would be or not to use the VMG4005-B50A in the UK with my BT VDSL connection?
I would probably connect my NBG7510 to it as the router.
I am thinking about updating my home setup.
Kind regards,
Tony
Hi all,
I have ordered one, as there is a thread on the Kitz forum that suggests that it should be able to work in the UK.
https://forum.kitz.co.uk/index.php/topic,25830.msg440515.html#msg440515
Kind regards Tony
Hi all,
I have got VMG4005 working with the firmware ABQA.2.1 in bridge mode together with my NBG7510.
However, I have a query about DHCP settings, as follows:
- If I want my NBG7510 router to get its WAN IP address automatically from my ISP, then what settings do I need to have in the VMG4005?
- I thought about DHCP relay, but I do not know what address to use for DHCP relay to for my ISP.
- If I just left it as DHCP Disabled in the VMG4005 then would all the PPPoE pass through the VMG4005 and just work and give my NBG7510 a WAN IP address automatically?
- Do I need to enable PPPoE passthrough on the VMG4005? I set-up PPPoE on my NBG7510 router.
- My NBG7510 worked with PPPoE if I set it to statically have the WAN IP address that my ISP has given out to my existing VMG1312-B10D device.
- Is this going to work long term if my ISP ever decides to change my IP address?
Thoughts?
Kind regards,
Tony
0 - If I want my NBG7510 router to get its WAN IP address automatically from my ISP, then what settings do I need to have in the VMG4005?
- 237 Nebula Ideas
- 6.8K Security
- 740 USG FLEX H Series
- 376 Security Ideas
- 58 Wireless Ideas
- 7.2K Consumer Product
- 319 Service & License
- 512 News and Release
- 99 Security Advisories
- 5.3K FAQ
- 91 About Community
- 119 Security Highlight
