How do I use cellular backup on LTE3301-PLUS/FWA510/FWA505?
Zyxel_Jay
To use cellular backup on LTE3301-PLUS, FWA510, or FWA505, follow these steps:
1.Login to the Mobile Router WebGUI:
Connect your device to the router.
Open a web browser and enter the default IP address: https://192.168.1.1.
Log in using your password.
2. Enable Ethernet WAN:
Navigate to Network Setting > Broadband > EtherWAN.
Set State to Enable.
Apply the configuration and wait for the mobile router to reboot.
3.Configure WAN Backup:
After the router reboots, go to Network Setting > Broadband.
You will see an new option for WAN Backup.
Enable and configure the WAN backup settings.
Noted: the option "The Destination for Connection Check" need to set up the destination that both cellular WAN and EtherWAN can ping.
- 244 Nebula Ideas
- 6.9K Security
- 807 USG FLEX H Series
- 392 Security Ideas
- 88 Switch Ideas
- 60 Wireless Ideas
- 7.3K Consumer Product
- 333 Service & License
- 541 News and Release
- 106 Security Advisories
- 5.5K FAQ
- 89 About Community
- 124 Security Highlight
