How to Enable 160MHz Channel Width in Nebula
Zyxel_Jami
in Radio
The 160 MHz channel width option is not shown on the general 'Radio Setting' page because it applies to the entire site, and not all AP models support 160 MHz.
After confirming device is on the 160 MHz supported model list, you can set it on a per-AP basis:
- Go to Configure > Radio settings > AP list (at the bottom of the page).
- Select "5GHz".
- Check the APs you want to adjust and click "Edit".
- Select "160 MHz" under Channel width and click "Update".
- 234 Nebula Ideas
- 6.7K Security
- 732 USG FLEX H Series
- 373 Security Ideas
- 57 Wireless Ideas
- 7.1K Consumer Product
- 319 Service & License
- 511 News and Release
- 99 Security Advisories
- 5.2K FAQ
- 89 About Community
- 117 Security Highlight
