VPN connection between USG Flex 200 and a draytek Vigor2865
Hi ive setup a IPSec LAN to LAN connection i believe ive set both ends up correctly but im not getting a connection the Flex 200 is connected vias nebula i keep getting these logs
The cookie pair is : 0x964c3abc2f8f2298 / 0x0000000000000000
Recv:[SA][VID][VID][VID][VID][VID][VID]
Recv Main Mode request from ]
Send:[NOTIFY:NO_PROPOSAL_CHOSEN]
[ID] : Tunnel [SA_Claieville] Local IP mismatch
[SA] : No proposal chosen
Recv IKE sa: SA([0] protocol = IKE (1), AES CBC key len = 256, HMAC-SHA256 PRF, HMAC-SHA256-128, 2048 bit MODP; ).
Cheers Dan
Hi @Baydale
It looks like the VPN connection is being established between Nebula and non-Nebula devices, causing a local IP mismatch error. To better understand your setup, could you please provide your network topology and the application scenario for your VPN connection?
If you are setting up a site-to-site VPN between Nebula and non-Nebula devices, you might find this guide helpful:
Kay
Hi @Baydale
Kay
- 243 Nebula Ideas
- 6.8K Security
- 781 USG FLEX H Series
- 387 Security Ideas
- 58 Wireless Ideas
- 7.2K Consumer Product
- 324 Service & License
- 527 News and Release
- 101 Security Advisories
- 5.3K FAQ
- 91 About Community
- 121 Security Highlight
