How to check the maximum power consumption for the switch?
Zyxel_Judy
Zyxel_Judy Posts: 2,800
image  Zyxel Employee
You can find the minimum power consumption for the switch in the datasheet that can be found in the Zyxel download library.
For instance, the maximum power consumption for the XGS1930-28 is 24.6 watts. You can refer to the datasheet here:
https://download.zyxel.com/XGS1930-28HP/datasheet/XGS1930-28HP_6.pdf
Zyxel_Judy
