How to Resolve HA Pro Sync Issue on ATP/USG FLEX?
Zyxel_Emily
Question:
Why is the HA Pro synchronization failing on ATP/USG FLEX?
Answer:
Synchronization issues between active and passive devices in HA Pro setups can often be resolved by checking configuration settings. Please follow the steps below:
- Make sure the passive device is reset to its default configuration.
- Disable any customized zones for the heartbeat port (e.g., For USG FLEX 700, set the zone to "none" for the heartbeat port ge12).
- Attempt to run the HA Pro synchronization again.
If issues persist, use the command on the passive device to collect HA sync logs.
Router> show device-ha2 trace-log
- 243 Nebula Ideas
- 6.9K Security
- 793 USG FLEX H Series
- 391 Security Ideas
- 88 Switch Ideas
- 59 Wireless Ideas
- 7.3K Consumer Product
- 327 Service & License
- 530 News and Release
- 104 Security Advisories
- 5.4K FAQ
- 91 About Community
- 122 Security Highlight
