sharing between wifi networks
I would like to connect my neighbor's WIFI to my own WIFI network so we can share resources. Is there a way to do this versus STATION<>AP? I'm assuming this would require some form of WDS between them? My neighbor just has a comcast wifi router and I'm using a NWA110AX for equipment
    PeterUK image  Guru Member
    edited July 2024
    Hmmm it might work with your neighbour as repeater to say your AP as root or other way round by WDS for a given VLAN SSID.
    or you could just both be root and they connect to your SSID
  • ok…so she uses a comcast soho wifi router
  • Zyxel_Kay
    Zyxel_Kay image  Zyxel Employee
    Hi @michaelstaylor
    To maintain stable connectivity, our AP WDS connection can only be established between Zyxel APs that are in standalone mode. If your neighbor is using a non-Zyxel AP, it will not be possible to build a WDS connection between them. For more details about Zyxel mesh technologies, you may refer to this article:
    You might consider other ways to achieve this connection, such as purchasing another Zyxel AP to install at your neighbor's location or using a different method.
    Kay
