Recycle Bin does not work when deleting from SMB
Verz
Verz Posts: 2
image  Freshman Member
Hi, my Zyxel Nas 326 do not move files into the recycle folders when I access it through SMB via my Linux machine. On the serve is running an instance of Nextcloud.
Instead, if I delete them via my SMB application on my phone they are correctly moved into the recycle folders.
Could you help me?
Thank you
  • Verz
    Verz Posts: 2
    Solved, it was an issue with my Nextcloud. Configured the config.php file to define the retention date
  • Verz
    Verz Posts: 2
