How to resolve APIPA addresses for clients connected to Wi-Fi?
Zyxel_Bella
Zyxel_Bella Posts: 620
Zyxel Certified Network Engineer Level 2 - Switch Zyxel Certified Network Engineer Level 1 - Switch Zyxel Certified Network Administrator - Switch 50 Answers
image  Zyxel Employee
If clients are receiving APIPA addresses, it likely indicates that they cannot obtain an IP address from the DHCP server.
Start by checking the DHCP server logs in Nebula under Monitor > WiFi Aid & Connection log.
If the logs show that the DHCP pool is full like below:
DHCP server (Firewall/AP NAT) Cannot find any lease for this client - B2:67:4B:CC:BB:AA, DHCP pool full!
DHCP client [WiFi Aid] B2:67:4B:CC:BB:AA failed to receive an IP address due to DHCP failure/timeout (No response after discover), SSID: Studios.
It stands for the DHCP server not being able to allocate IP addresses to some clients due to a full DHCP pool. Specifically, the log entry shows that the DHCP server is unable to find a lease for the client.
When the DHCP pool is full, new devices trying to connect may not receive an IP address and end up with an APIPA address.
You could follow these steps to resolve:
1. Increase the DHCP Pool Size: Expand the DHCP pool to accommodate more devices.
2. Review Lease Times: Shorten the DHCP lease time to free up IP addresses more quickly.
These adjustments should help in resolving connectivity issues for your clients.
