Access Point not shifting devices between AP
Hi Peers,
I am not tech savvy so apologies in advance.
I have several AP and have them set up with 1 SSID. The issue I am having is when a device goes out of range of 1 AP it doesn't connect to a stronger AP.
Can you advise how do I correct this?
Best Answers
Hi @Fuisdale2,
Thanks for the information~ Please reference this FAQ for Nebula control center:
How to Set up Seamless Wireless Roaming on Nebula? — Zyxel Community
Zyxel Melen0 -
Hi @Fuisdale2,
Only if you plan to use SSID tagging. If you don't have a plan, then you don't need to configure it.
Zyxel Melen0
Hi @Fuisdale2,
You may reference these FAQs to help you configure the needed settings.
Zyxel Melen0 -
I have had a look at the setting up wireless roaming and tried to follow the steps but my nebula cloud doesn't look like the pictures. is there an up to date version of the document?
Hi @Fuisdale2,
Zyxel Melen0 -
I have followed the guide and am I correct in my understanding once I set up the SSID and Password and Add "Tags" to each of the API that I want to set roaming between is all that is required?
Hi @Fuisdale2,
Zyxel Melen0
- 243 Nebula Ideas
- 6.9K Security
- 793 USG FLEX H Series
- 391 Security Ideas
- 88 Switch Ideas
- 59 Wireless Ideas
- 7.3K Consumer Product
- 327 Service & License
- 530 News and Release
- 104 Security Advisories
- 5.4K FAQ
- 91 About Community
- 122 Security Highlight
