Firewalls and switches hardware monitoring
Hello everyone,
I noticed that on XGS2220-54HP there is fan monitor just above ports on Nebula webpage:
Is it possible to find the same panel also for other hardwares?
For example for USG Flex 500:
And for XMG1915-18EP:
Actually there is no panel like that as you can see on the Nebula page for the last switch I mentioned:
Hi @GiuseppeR
The hardware monitoring feature depends on the device's capabilities. For the XMG1915 series switch, hardware monitoring is available in standalone mode, but only for temperature monitoring, as the fan status is not supported due to hardware limitations. The good news is, it supports for hardware monitoring on the Nebula Control Center (NCC) is planned for the future. Please stay tuned for updates in the section.
You can also refer to the Nebula Device Function Table for more details on the current device specifications.
Regarding firewalls, hardware monitoring is currently not supported. However, your suggestion is valuable! I’ve created a feature request idea post based on your feedback:
If you or others are interested in this feature, feel free to vote and leave a comment. Votes and comments contribute to the feature evaluation process.
Kay
Hi @GiuseppeR
Kay
- 241 Nebula Ideas
- 6.8K Security
- 758 USG FLEX H Series
- 380 Security Ideas
- 58 Wireless Ideas
- 7.2K Consumer Product
- 321 Service & License
- 520 News and Release
- 100 Security Advisories
- 5.3K FAQ
- 90 About Community
- 119 Security Highlight
