Problem with registration of device on Nebula. Wrong model of device
Santin
Santin Posts: 1 image  Freshman Member
Hi.
There was a problem registering the device with Nebula. When entering the MAC and Serial number, the model is determined to be ATP200, although it should be APT800. What could be the problem?
  • Zyxel_Melen
    Zyxel_Melen Posts: 5,110
    image  Zyxel Employee
    edited October 2024 Answer ✓
    Update: The issue was solved by correcting the wrong data.
    Zyxel Melen
  • Zyxel_Melen
    Hi @Santin,
    Could you provide the detail information for me to check? I will send you a private message to collect these information.
    Zyxel Melen
  • Zyxel_Melen
    Zyxel Melen
Nebula Tips & Tricks
