info
Ciao @dany
Potresti fornirci il modello del dispositivo che stai utilizzando?
La lista dei client su Nebula CC mostrerà solo i client connessi ai firewall, switch, access point o router di sicurezza gestiti da Nebula. Se desideri visualizzare i client collegati al tuo router mobile Nebula, puoi utilizzare la funzione "Live Tools" su NCC. Ecco un articolo per maggiori informazioni:
Hi @dany
Could you please provide us with the specific device you are using?
The Nebula CC client list will only display clients connected to your Nebula-managed firewalls, switches, access points, or security routers. To view clients connected to your Nebula mobile router, you can use the "Live Tools" feature on the NCC. For more details, you can check the following article:
How to Check Clients on Nebula Mobile Router? — Zyxel Community
Kay
Ciao @dany
Hi @dany
Kay
fwa 505 grazie
Ciao @dany
Il Nebula FWA505 è un router mobile Nebula. Ti invito a consultare l'articolo sopra per le istruzioni su come verificare i dispositivi connessi.
Hi @dany
The Nebula FWA505 is a Nebula mobile router. Please refer to the article above for steps on checking your connected clients.
Kay
- 237 Nebula Ideas
- 6.8K Security
- 740 USG FLEX H Series
- 376 Security Ideas
- 58 Wireless Ideas
- 7.2K Consumer Product
- 319 Service & License
- 512 News and Release
- 99 Security Advisories
- 5.3K FAQ
- 91 About Community
- 119 Security Highlight
