Pairing problem NAS326
danko
danko Posts: 28
image  Freshman Member
I accidentally unpaired my NAS 236 from my cloud.zyxel.com.
Now, when I try to pair, I start "search", then "Manually Add" and enter the MAC and serial, and when the search starts, which should last 10 minutes (from which time I need to press the button on the device), the peocedure stops after 5-6 seconds and I get the message "Device not found".
Before accidentally deleting the pairing, everything was working fine. What's the problem?
  • danko
    danko Posts: 28
    Problem solved….
    Reinstaling mycloud app on NAS.
  • danko
    danko Posts: 28
    Problem solved….
  • Dangos65
    Dangos65 Posts: 2
    Great!
    Solved my problem!
