Difference between ZyXel FWA-710-EU0102F vs FWA710-EUZNN1F
Hi @phayze
There is no difference in product features or sales policies between the FWA-710-EU0102F and FWA-710-EUZNN1F. These model codes are primarily used internally for tracking product part numbers. Rest assured, the functionality and specifications are identical for both.
Both models support standalone mode as well as Nebula cloud management. While they work perfectly in standalone mode, we highly recommend adding the device to Nebula for enhanced management capabilities. Once registered on the Nebula Control Center (Nebula CC), you can remotely access the device's web configurator and take advantage of features like scheduled reboots.
Local access remains available if you prefer to adjust settings directly. However, please note that when the device is registered to Nebula, the web configurator login credentials will follow the password set in the Nebula CC site settings.
Kay
Hi @phayze
Kay
- 243 Nebula Ideas
- 6.9K Security
- 794 USG FLEX H Series
- 391 Security Ideas
- 88 Switch Ideas
- 59 Wireless Ideas
- 7.3K Consumer Product
- 327 Service & License
- 530 News and Release
- 104 Security Advisories
- 5.4K FAQ
- 91 About Community
- 122 Security Highlight
