How to adjust the antenna mounting mode when managed in Nebula?
Zyxel_HsinBo
Zyxel_HsinBo Posts: 532
Zyxel Certified Network Engineer Level 2 - Switch Zyxel Certified Network Engineer Level 1 - Switch Zyxel Certified Network Administrator - Security Zyxel Certified Network Administrator - WLAN
image  Zyxel Employee
You can adjust the AP's mount mode from below 2 paths:
1. Nebula » Configure » Radio settings page
Scroll down the page to the AP table, and you'll be able to adjust the mounting mode configuration of the support wall mount models.
2. Nebula » Devices » Access points page
Tap on the AP which support wall mount deployment and you'll be able to adjust the mounting mode configuration by clicking the Edit icon.
