How to Extend WiFi Coverage with FWA510?
Zyxel_Jami
Zyxel_Jami image  Zyxel Employee
Zyxel Certified Network Administrator - WLAN Zyxel Certified Sales Associate First Comment Friend Collector
edited December 2024 in Nebula Mobile Router
The FWA510 does not support mesh mode. However, you can improve WiFi coverage by connecting additional access points (APs) to the LAN port of the FWA510.
This setup enhances wireless coverage in your area without requiring multiple mobile SIM cards.
Steps to Extend WiFi Signal:
  1. Obtain a compatible AP, such as the WAX610D, which supports WiFi 6 and is suitable for a high-density user environment.
  2. Physically connect the AP to the LAN port of your FWA510 using an Ethernet cable.
  3. Configure the AP through the Nebula Control Center by navigating to Site-wide > Configure > SSIDs to set up SSIDs and passwords.
  4. Manage your network in real time via the Nebula Cloud Management platform (https://nebula.zyxel.com/).
This solution allows you to boost the signal effectively without the need for additional SIM cards.
