What Steps Should I Follow to Improve 5G Signal Reception for FWA505?
Zyxel_Jami
To improve your 5G signal reception, follow these steps:
- Move your router closer to a window or open space to reduce interference from walls and obstacles.
- Consider using external antennas to enhance signal reception. The Zyxel device has two TS9 connectors for this purpose.
For further details on selecting appropriate external antennas, consider those supporting a frequency range of 700-4200 MHz with a gain greater than 5dBi, and choose between omnidirectional or directional antennas based on your environment.
If you need the recommended external antenna information, please reference:
What type of external antenna is recommended for the FWA505? — Zyxel Community
- 244 Nebula Ideas
- 6.9K Security
- 801 USG FLEX H Series
- 392 Security Ideas
- 88 Switch Ideas
- 59 Wireless Ideas
- 7.3K Consumer Product
- 329 Service & License
- 532 News and Release
- 104 Security Advisories
- 5.5K FAQ
- 91 About Community
- 124 Security Highlight
