Jason
BPDU block on edge and mac-limit
jonashauge
it would be a great addition making it possible to block/shutdown edge switchports if a spanning-tree BPDU is seen or number of mac addresses raises over a certain level.
The background for this request is to limit users from installing third party switches which can break your topology.
Bonus would be to do spanning-tree root guard as well.
Overall that would raise the enterprise capability of the products quite significantly.
Hi @jonashauge ,
Welcome to Zyxel Community!
From your description, I think you are talking about the BPDU guard which we have already had the feature that you may configure on NCC.
You may go to "SWITCH > Configure > Switch ports > (Choose ports) > STP guard" to configure.
Hope it helps.
- 242 Nebula Ideas
- 6.8K Security
- 764 USG FLEX H Series
- 385 Security Ideas
- 58 Wireless Ideas
- 7.2K Consumer Product
- 323 Service & License
- 522 News and Release
- 100 Security Advisories
- 5.3K FAQ
- 91 About Community
- 121 Security Highlight
