Nebula switch management - no Voice VLAN on trunk port
electsystech
electsystech Posts: 61 image  Ally Member
First Answer First Comment Friend Collector Seventh Anniversary
Nebula does not appear to allow 'trunk' ports (which are required for multiple 'tagged' VLANs) to be assigned a voice VLAN via LLDP. We design our networks as 'device agnostic' e.g. plug any device into any port and this lack of functionality causes a problem. Is there a way to provision 'LLDP voice VLAN' and 'multiple VLAN tagging" on the same port as can be done when a switch in not in Nebula?
If not - it's a feature request.
  • Zyxel_Melen
    Zyxel_Melen Posts: 5,077 image  Zyxel Employee
    edited January 2025
    Hi @electsystech,
    The trunk mode doesn't have the Voice VLAN option because the concepts are different.
    Voice VLAN separates voice data from other traffic, the purpose of which differs from the trunk port that can carry traffic for multiple VLANs over a link.
    Since most of MSI/IT design the network with clear plan, which ports are for PC and which are for specific devices, therefore, please change the port type from trunk to access once you connect an IP Phone.
    Zyxel Melen
  • electsystech
    edited August 2025
    That doesn't provide the requested solution. We are requesting all ports to be device type agnostic. (Plug any device into any port and LLDP will assign it to the correct VLAN). This can be done when the switch in not in Nebula. Its a limitation of Nebula.
  • Zyxel_Melen
    Hi @electsystech
    I understand. Could you share the effect that Nebula doesn't support the 'trunk' ports (which are required for multiple 'tagged' VLANs) being assigned a voice VLAN via LLDP? This information will help with this issue.
    Zyxel Melen
Nebula Tips & Tricks
