How to set up a vlan for WiFi SSID on nebula AP ?
Zyxel_JoyLee
Zyxel_JoyLee Posts: 244
Friend Collector First Anniversary
image  Zyxel Employee
To set up a VLAN for your wireless network, you'll need to configure your Zyxel switch and access point. First, create a new VLAN on your switch and assign it a unique VLAN ID. Then, configure the ports on your switch to be members of the VLAN. Finally, on your access point, create a new SSID and associate it with the VLAN you created. This will allow devices connected to that SSID to communicate only with other devices on the same VLAN.
Site-wide > Configure > Access points > SSID advanced settings > Advanced settings > VLAN ID and then click "Save" button
