Do Not Enable Dynamic Personal PSK (DPPSK) and MLO Function Together to Avoid SSID Disappearance
Zyxel_JoyLee
This is a known design limitation.
Currently, DPPSK supports only WPA2 security, while MLO with the 6 GHz band enabled requires WPA3 security. As a result, an irreconcilable conflict occurs during the security configuration process.
Furthermore, the 6 GHz band does not support DPPSK. If you wish to use DPPSK with the MLO function, you can disable the 6 GHz band in the band mode settings.
Navigate to Site-wide > Configure > Access points > SSID advanced settings > Band mode > uncheck 6 GHz band
- 237 Nebula Ideas
- 6.8K Security
- 740 USG FLEX H Series
- 376 Security Ideas
- 58 Wireless Ideas
- 7.2K Consumer Product
- 319 Service & License
- 512 News and Release
- 99 Security Advisories
- 5.3K FAQ
- 91 About Community
- 119 Security Highlight
