Zyxel DX3301 and NWA50AX Mesh
Hi @adz6482,
NWA50AX supports Mesh technology, but DX3301 and NWA50AX use different Mesh systems/mechanisms, so they can't work together. If you want to extend your Wi-Fi coverage, consider setting the identical SSID and security option to implement Wi-Fi roaming at home.
Here are some FAQ for your reference:
- The Difference Between Roaming and Mesh in Wireless Networks — Zyxel Community
- How to Set up Seamless Wireless Roaming? — Zyxel Community
- How to Set up Seamless Wireless Roaming on Nebula? — Zyxel Community
Hope it helps.
Zyxel Melen0
Hi @adz6482,
Hope it helps.
Zyxel Melen0
- 242 Nebula Ideas
- 6.8K Security
- 780 USG FLEX H Series
- 387 Security Ideas
- 58 Wireless Ideas
- 7.2K Consumer Product
- 324 Service & License
- 527 News and Release
- 101 Security Advisories
- 5.3K FAQ
- 91 About Community
- 121 Security Highlight
