LTE7490 Ethernet Link Down/Up on LTE lost
cyayon
cyayon Posts: 10
image  Freshman Member
On LTE7490-M904 with the current last firmware, I have an issue about the ethernet port which go down and up on LTE carrier lost (each 24h in France).
It is an issue for me and I would like to know if it possible to avoid or workaround this ?
Moreover, there is an Network Monitoring option on Broadband / Cellular Wan section, what is it for ?
Finally, where could I find the CLI reference guide for this model ? Perhaps, there is a CLI command to avoid ethernet reset on LTE lost ?
Thanks.
  • Zyxel_Krystal
    Zyxel_Krystal Posts: 11
    First Comment First Answer Friend Collector
    How is the signal strength?
    We would suggest to enable the Network Monitoring function, this will help device to recover when disconnection happens.
    thank you
