How Does Signal Strength Impact Wireless Client Connections?
Zyxel_Jami
Zyxel_Jami Posts: 245 image  Zyxel Employee
Zyxel Certified Network Administrator - WLAN Zyxel Certified Sales Associate First Comment Friend Collector
Signal strength plays a critical role in the stability and quality of a wireless client's connection. Here's why:
  • Weaker signals lead to more data errors:
    When the client device receives a weak Wi-Fi signal, data packets are more likely to be lost or corrupted during transmission. This results in retransmissions, increased delays, and slower overall performance.
  • Poor signal strength increases latency and jitter:
    Fluctuating or low signal levels can cause higher latency and inconsistent packet delivery. This leads to buffering or dropped connections, particularly noticeable during real-time activities such as video calls, VoIP, or online gaming.
  • Client devices may disconnect or fail to roam properly:
    If signal strength drops below a critical threshold, wireless clients may disconnect or struggle to maintain a stable connection, especially when moving between access points or across coverage zones.
To ensure a stable and smooth wireless experience, it’s recommended that the client device maintains an RSSI (Received Signal Strength Indicator) of better than -65 dBm.
