How to dimm or disable LED on NWA130BE ?
Jeoffrey
Jeoffrey Posts: 3
image  Freshman Member
As there is no option like described in this article (https://community.zyxel.com/en/discussion/17906/how-to-disable-leds-on-your-aps) in the local web admin maintenance pages, how to do ?
Why this is missing ?
My AP are in v7.20 firmware, cloud managed.
Best Answers
  • Zyxel_Melen
    Zyxel_Melen Posts: 5,279
    image  Zyxel Employee
    Hi @Jeoffrey
    Please help to navigate to Nebula CC > your org & site > Menu > Site-wide > Configure > Access points > AP & port settings to disable the LED lights setting. This setting will be applied to all of AP in this site.
    Zyxel Melen
  • Jeoffrey
    Jeoffrey Posts: 3
    So no way to just Dimm the LED, or to set it one by one if we don't want a global setting ?
  • Zyxel_Melen
    Hi @Jeoffrey
    Zyxel Melen
  • Jeoffrey
    Jeoffrey Posts: 3
  • Zyxel_Melen
    Hi @Jeoffrey
    If you want to disable the LED for specific AP, please navigate to the Menu > Devices > Access point page to select the APs and add "LED_off" tag. Here is the guide video.
    https://jam.dev/c/e79f9554-8009-4bab-9977-08f94ccb2936
    Zyxel Melen
Nebula Tips & Tricks
