Is it possible to set Wi-Fi output power on USG LITE 60AX, e.g. 50%?
Pe990
Pe990 Posts: 2 image  Freshman Member
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,916 image  Zyxel Employee
    Hi @Pe990
    Yes, you can adjust the Wi-Fi output power on the USG LITE 60AX, but it's set in dBm rather than as a percentage.
    To configure this in the Nebula Control Center (NCC):
    1. Navigate to `Site-wide > Configure > Security router > Radio settings`.
    2. Scroll to the bottom of the page.
    3. Select your USG LITE 60AX model and click "Edit."
    4. Locate the "Maximum output power" field to adjust the value, which typically ranges from 1 to 30 dBm.
    Zyxel Melen
  • Zyxel_Melen
    Hi @Pe990
    Zyxel Melen
Nebula Tips & Tricks
