Topology error when calculating LACP speed
Hello everyone,
inside an ORG I used 3x gigabit RJ45 to link 2x switches, but the LACP settings on both sides are related to 4x ports.
The issue is the fact that the Topology shows me the link at 4 Gbps also when I use only 3x cables:
How can I fix that?
Hi @GiuseppeR,
To help us reproduce the issue locally, could you please clarify the following:
- The models of the two switches
- Their firmware versions
Additionally, please enable Zyxel Support Access and share the org/site name with us.
Thank you for your cooperation!
Zyxel Tina
Hi @Zyxel_Tina
model on the left GS1915-24E:
model on the right GS1920-24HP:
Sent you a PM with remote access.
Hi @GiuseppeR,
After confirming, the LACP speed shown in NCC topology is based on configured port count × individual port speed (e.g., 4×1G = 4Gbps), regardless of actual link-up status. This is the current spec design.
We understand this behavior can be confusing, so our team is actively discussing enhancements for better user experience.
We've also created an ideas post. We encourage you and other users who are interested to show your support by commenting on or voting for it.
Thank you for your patience and understanding!
Zyxel Tina
Hi @Zyxel_Tina
thanks for the update.
It should be great also considering that other links inside the Topology have the ability to show degraded performances.
- 244 Nebula Ideas
- 6.9K Security
- 804 USG FLEX H Series
- 392 Security Ideas
- 88 Switch Ideas
- 60 Wireless Ideas
- 7.3K Consumer Product
- 330 Service & License
- 537 News and Release
- 106 Security Advisories
- 5.5K FAQ
- 91 About Community
- 124 Security Highlight
