NR5103EV3 5G connection issue
Hi Zyxel Tina
That's ok.
Yes I was hoping the DNS over HTTPS/TLS was built into the router as a security measure but if that's not in these products, then I won't be looking to add a separate firewall for that purpose.
I have since bought the Zyxel NR5103EV3 and I find it's features to be similar to the one you mentioned
Nebula FWA515 indoor 5G router - what I'm discovering now is it's 5G connection rarely happens but when I put the sim in my phone I get it no problem - so what have I got, a faulty device? I updated the firmware but that hasn't really helped.
Is there anything I can do about this?
Hi Zyxel_Tina
Ok thanks for doing that, makes sense.
I'm going to get an external antenna for it - have you any recommendations?
Also. where can I download the firmware for this device, seems I can only update over the air - I want to do it locally to see if that makes a difference.
And, are there going to be further firmware updates?
Is there a way to enable IP Passthrough on the device?
- 241 Nebula Ideas
- 6.8K Security
- 760 USG FLEX H Series
- 381 Security Ideas
- 58 Wireless Ideas
- 7.2K Consumer Product
- 323 Service & License
- 521 News and Release
- 100 Security Advisories
- 5.3K FAQ
- 90 About Community
- 119 Security Highlight
Admin
