FWA515 - 2.4GHz / MLO problems
NoTurner
NoTurner Posts: 3 image  Freshman Member
Hi there, my FWA515 has got some problems with 2.4GHz too, some users are complaining about 2.4GHz issues and there's still no firmware update. 2.4GHz drops and all of my 2.4GHz devices (smart home) lose connection and are not functioning till I restart the FWA515. That's unacceptable. A firmware update would be great to address this issue. Thanks.
  • Zyxel_Tina
    Zyxel_Tina Posts: 913 image  Zyxel Employee
    Zyxel Certified Network Administrator - Security Zyxel Certified Network Administrator - Switch 100 Answers 500 Comments
    edited June 24
    Hi @NoTurner,
    Welcome to the Zyxel Community!
    Regarding the issue you are encountering, we have received similar reports from other users. We are still preparing the new firmware.
    As a temporary workaround, if your device's 2.4 GHz channel is currently set to Auto, we recommend manually setting it to channel 1, 6, or 11. After making this change, please monitor the 2.4 GHz connection to see if the issue improves. This is because when the channel is set to a non-standard value (other than 1, 6, or 11), some IoT devices may have difficulty detecting the signal.
    Additionally, please try turning the 2.4 GHz radio off and then back on again to see if the connection can be restored, instead of rebooting the entire device.
    If the issue persists, please collect the system log when the issue occurs and send it to us via private message by clicking my profile > Message, along with the timestamp for further analysis.
    Thank you for your cooperation.
    Zyxel Tina
  • NoTurner
    edited July 1
    Hello, for some reason, my Zyxel FWA515 sometimes restarts on its own without setting "Maintenance" (reboot) in Nebula control center. I really don't know why but it's not stable at all. I may end up returning this router, it's having excellent hardware but the software is not really what I expected from Zyxel. Log attached.
    (The Zyxel agent has removed the log for security reasons.)
  • Zyxel_Tina
    edited July 1
    Hi @NoTurner,
    Thank you for providing the log.
    This kind of unexpected reboot may also be related to the power supply. Could you please let us know how the device is being powered? Are you using the original Zyxel power adapter? An unstable power source or a non-original adapter may sometimes cause unexpected restarts.
    Additionally, please try connecting the device to a different power outlet on its own to see if the issue improves.
    If the issue persists after the above troubleshooting, please let us know.
    Zyxel Tina
