Why is my FWA510 router showing a red indicator light and not connecting to NCC?
Zyxel_Jami
If your Zyxel FWA510 router indicates a red light and cannot connect to the Nebula Control Center (NCC), follow these steps:
- Ensure ports 4335 and 6667 are not blocked by your firewall or Internet Service Provider (ISP). These ports are essential for NETCONF communication with NCC.
- Verify that your router is connected to the internet. You can check this through the device’s Web GUI by connecting your PC to the LAN port or the router's SSID.
- Confirm that NCC Discovery is enabled on your device. This can usually be managed in the router's settings via its Web GUI.
- Restart your router and check all cables. Unplug the device for 10 seconds and then reconnect it.
- Make sure the router is assigned to the correct site under the 'Site-wide > License & Inventory' section in NCC.
If the issue persists after carrying out these steps, please consider enabling support access and submit a support ticket for further assistance. Guidance can be found in the following articles:
- 243 Nebula Ideas
- 6.8K Security
- 783 USG FLEX H Series
- 389 Security Ideas
- 58 Wireless Ideas
- 7.2K Consumer Product
- 325 Service & License
- 527 News and Release
- 101 Security Advisories
- 5.3K FAQ
- 91 About Community
- 122 Security Highlight
