NR7101 Does Not retain settings after reboot
xDonald
after a reboot the router always falls back to the default credentials. The rest of the configuration survives the restart. Is this a known bug of the firmware?
I'm using the router in passthrough mode, no wlan or special services in use.
Thanks in advance
— Don
Current Firmware Version: 1.00(ABUV.10)C0
Current LTE Module Version: RG502QEAACR13A05M4G_ZYXEL
Hi xDonald,
You can download the 11C0 from the link below.
V1.00(ABUV.11)C0is the latest firmware version released to end customers. You can try resetting the device to check whether the issue persists.Best
Brandon
i updated from ABUV.08 to ABUV.10 already because i thought it may fix it. Do you think this ABUV.11 may be fixing it?
- 241 Nebula Ideas
- 6.8K Security
- 755 USG FLEX H Series
- 380 Security Ideas
- 58 Wireless Ideas
- 7.2K Consumer Product
- 321 Service & License
- 512 News and Release
- 99 Security Advisories
- 5.3K FAQ
- 90 About Community
- 119 Security Highlight
