Firmware Request: Manual update / transition path for NR5307 stuck on V1.00(ACOM.0)b1
Hi Zyxel Support Team,I am currently using a Zyxel NR5307 5G router (photo attached)
. The device is currently running the customized carrier firmware version V1.00(ACOM.0)b1 (Hiper ISP branch).Because it is running this specific provider build, the built-in Over-the-Air (FOTA) upgrade tool states that no newer firmware is available. However, I want to update the device to secure it against recent security vulnerabilities (such as CVE-2024-5412) and stabilize the connection.I am looking to transition this router over to the generic/global baseline firmware track (such as 1.00(ACJT.0)B6 or the latest available ACJT release).
Could you please provide:
- The standard
.binfile for the latest global firmware release for the NR5307. - Any necessary transition/migration firmware file required to bypass the
ACOMcarrier lock if a direct flash isn't supported by the GUI.
Thank you for your time and assistance!
Damian
Hi everyone,I am facing the exact same issue with my Zyxel NR5307. I purchased this device second-hand, and it is currently locked to a foreign carrier (Odido / former T-Mobile Netherlands). Because of this carrier-customized firmware, I am completely unable to configure national APN parameters or use any Italian SIM cards, as the network connection is entirely restricted. I would like to kindly request the official generic/global baseline firmware track file (such as the ACJT release) and any necessary transition path firmware to bypass the current provider lock through the GUI.Here are my device details:
Model: Zyxel NR5307
Current Firmware Version: QuectelT830R03A01_xx.001.xx.001 / V1.00(ACOM.0)b1
Thank you so much in advance for your support!Best regards,
Franco
"Hi, I have the exact same problem with my second-hand NR5307 stuck on V1.00(ACOM.0)b1 here in Sweden. Could a moderator please send me the global ACJT firmware file via private message as well? Thank you!"
- 243 Nebula Ideas
- 6.8K Security
- 783 USG FLEX H Series
- 389 Security Ideas
- 58 Wireless Ideas
- 7.2K Consumer Product
- 325 Service & License
- 527 News and Release
- 101 Security Advisories
- 5.3K FAQ
- 91 About Community
- 122 Security Highlight
