Expand Nebula OpenAPI for Advanced Gateway Monitoring and Diagnostics
ZCNE Certified
Hello Zyxel Team,
We are developing a centralized monitoring platform for Zyxel firewalls across multiple customer organizations, using the Nebula OpenAPI.
During integration with USG FLEX and ATP gateways, we identified several monitoring capabilities that are either unavailable or insufficiently documented in the current public API.
We would like to propose the following enhancements.
1. System Uptime
Endpoint: GET /v1/nebula/{siteId}/gw/{devId}/system-status
Please expose the actual system uptime, equivalent to the value displayed in the firewall's local GUI, rather than the SNMP management subsystem uptime.
2. Last Communication with Nebula
Endpoint: GET /v1/nebula/{siteId}/online-status
Please provide the UTC timestamp of the gateway's last successful communication with the Nebula cloud.
This would help determine how long a disconnected gateway has been offline.
3. Timestamped Traffic History
Endpoint: GET /v1/nebula/{siteId}/gw/{devId}/traffic-usage
The current API provides aggregated traffic usage for predefined periods, but not timestamped measurements.
We would appreciate historical upload/download data with timestamps, preferably at hourly or finer granularity, to make it possible to render a graph similar to the one in the GUI.
Clarification of the traffic units and transmission/reception semantics would also be helpful.
4. Gateway Event Log Severity
Endpoint: POST /v1/nebula/{siteId}/gw/event-logs
Please expose the severity or priority of each gateway event and indicate whether it is classified as an alert. It would also be helpful if the logs came decoded, with user-friendly messages, together with a full-log field if we need any other information about it.
The firewall's local GUI distinguishes alerts from ordinary logs, but this information is not available in the gateway event logs response.
5. Event Log Pagination and Filtering
The gateway event logs endpoint currently lacks documented pagination parameters.
Retrieving large time ranges can produce extremely large responses.
We suggest adding cursor-based pagination, a configurable result limit, and optional filtering by gateway devId.
6. Maximum Concurrent Sessions
Please expose the effective maximum concurrent session capacity of the gateway, alongside the existing active session count.
This would help determine session capacity utilization.
7. Configuration Change Audit
Please provide an API-accessible audit trail of gateway configuration changes, including timestamps, responsible administrators, affected configuration sections, and change actions, while protecting sensitive information.
8. Hardware Health and Ethernet Port Status
Endpoint: GET /v1/nebula/{siteId}/gw/{devId}/ports-status
Please clarify the distinction between No Link and Link Down, and consider exposing explicit administrative and operational interface states.
Hardware health indicators corresponding to PWR/SYS/USB, where supported, would also be valuable.
Why this matters
These capabilities would allow MSPs and integrators to build more complete and reliable monitoring solutions without relying on additional SSH/SNMP integrations or inferring information that the API does not explicitly provide.
We would appreciate confirmation if any of these fields are already available through other documented endpoints.
Thank you for considering these improvements!
Hi @dpipro
Just to confirm, your networks/environments are using USG FLEX/ATP in cloud management mode? I ask is because the Nebula Open API doesn't support USG FLEX/ATP in cloud monitoring mode.
Zyxel Melen0 -
Hi @dpipro
Below are the items we won't evaluate for now:
- Event log severity and decoded messages (item 4): Nebula doesn't display the severity of each gateway log, so this information is not available through the Open API. Please set up an external syslog server to get the severity and full log details.
- Event log pagination and filtering (item 5): Open API only provides raw data, so please handle paging and display on your own platform, and query shorter time ranges to keep the response size manageable. As for filtering by devId, based on the current design one site can only have one firewall, so a device filter is not needed.
- Maximum concurrent sessions (item 6): The maximum concurrent session capacity of each gateway model is public information on the device datasheet. Please check the datasheet directly.
- Ethernet port status, including No Link / Link Down and admin/operational states (item 8)
- Hardware health, PWR/SYS/USB (item 8): PWR/SYS/USB information is not supported on Nebula. We will evaluate providing CPU and memory information as device hardware information.
Our team will evaluate the remaining points and keep monitoring the comments and votes on this idea post.
Zyxel Melen0
- 244 Nebula Ideas
- 6.9K Security
- 800 USG FLEX H Series
- 392 Security Ideas
- 88 Switch Ideas
- 59 Wireless Ideas
- 7.3K Consumer Product
- 328 Service & License
- 532 News and Release
- 104 Security Advisories
- 5.5K FAQ
- 91 About Community
- 124 Security Highlight
