Remote Configurator with Nebula and USGFLEX100
parinotto
parinotto Posts: 5
image  Freshman Member
Hello
with this firewall I don not found the Remote Configurator tunnel (Live Tools), but with other firewall (H series) it's ok. Someone have an idea where is it? I'm quite sure that sometimes ago it was present on Nebula also for USGFLEX100. Thank you for help
  • Zyxel_Tina
    Zyxel_Tina Posts: 1,093
    Zyxel Certified Network Administrator - Security Zyxel Certified Network Administrator - Switch 250 Answers 1000 Comments
    image  Zyxel Employee
    Hi @parinotto ,
    The difference in behavior you are seeing between your USG FLEX 100 and the H-series firewall is due to how the two different product lines handle cloud management:
    USG FLEX 100 (and other original USG FLEX/ATP series):
    • Full Cloud Management Mode: When the USG FLEX 100 is fully managed by Nebula, all configurations are handled entirely via the Nebula Control Center (NCC). Because of this, the local Web GUI is disabled, and the Remote Configurator tool is not available.
    • Cloud Monitoring Mode: The Remote Configurator is only available on original USG FLEX devices if they are registered to Nebula in Cloud Monitoring Mode. In this mode, the firewall is monitored by the cloud but configured locally, allowing you to establish a secure tunnel to access its local Web GUI.
    USG FLEX H Series:
    • The H-series firewalls (running uOS) use a hybrid management architecture. Even when managed by Nebula, some advanced troubleshooting tools and configurations are accessed directly through the local Web GUI. Therefore, the Remote Configurator remains active under Live Tools for the H-series.
    Hope this helps!
    Zyxel Tina
Nebula Tips & Tricks
